Author Topic: Mk3 Golf GTi ABF Revs on it's own . . . any ideas please?  (Read 1443 times)
Offline Lukeabercynonnoi
This problem is really starting to annoy me. When I start the car up it decides to rev by itself, sometimes reaching up to 2500 revs!!
Does anyone know what is causing this? - I think its the fact that it is wasting my petrol (probably very little) but running a 2.0 litre you could use every bit of petrol you can get to be honest lol
Also when I stop at traffic lights and it revs by itself, people think I want to race them! haa
If anyone has any ideas what it could be it would be much appreciated
Thanks!
Offline justalex81
Re: Mk3 Golf GTi ABF Revs on it's own . . . any ideas please?
« Reply #1 on: 19 January 2010, 07:21 »
that'll could be your inlet manifold air pressure sensor. the back right hand side of the manifold there is a vacuum hose. if you trace it you'll see that it runs through the bulkhead and plugs into the ecu. replace the vacuum hose and see if that does the trick. if not i suggest you get vag-com on it to see what's up
Offline axewielder
  • 95 dragon 8v
« Reply #2 on: 19 January 2010, 10:05 »
could poss be a prob with charging system as engine will increase revs at idol to get the specified charge, happens more with all lights+_stereo on
Offline javalin
« Reply #3 on: 20 January 2010, 14:40 »
when you run vagcom - check the throttle position sensor (TPS) - too
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
« Reply #4 on: 20 January 2010, 16:33 »
+1 Plus try cleaning your throttle body and isv with carb cleaner.
