Author Topic: cams.... mk3 gti 8v or mk2 gti 8v?  (Read 3015 times)
Offline deanpompey
« on: 18 January 2010, 23:49 »
As per title guys, just wondering if a mk2 1.8 8v gti cam would be beneficial over the standard 2.0 8v item?
Offline axewielder
  • 95 dragon 8v
Offline deanpompey
Re: cams.... mk3 gti 8v or mk2 gti 8v?
« Reply #2 on: 20 January 2010, 09:29 »
that doesnt have the PB info though? so doesnt actually tell me which is better cam??
or am i missing something?
Offline axewielder
  • 95 dragon 8v
« Reply #3 on: 20 January 2010, 09:35 »
no sorry i couldnt get the figures for the pb, just lotsa info on cams  :drool:
« Reply #4 on: 20 January 2010, 10:16 »
Some people say the PB cam is hotter than the standard mk3 cam, I don't think so myself.
Offline bored_Welsh_lad
« Reply #5 on: 20 January 2010, 14:46 »
http://www.golfgtiforum.co.uk/index.php?topic=126869.10
Check out this thread for a guy who fitted a PB...
As for the mk2 vs mk3 cam issue.. i will check and get back to you
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline deanpompey
« Reply #6 on: 20 January 2010, 22:44 »
meh, for the hassle he had, i may as well just slap a schrick/newman/kent etc in there :)
cheers anyways guys
VW BUSH
« Reply #7 on: 21 January 2010, 13:34 »
cheers anyways guys
after grinding it down to fit the cam dropped in fine, it does not run lumpy and emissions although higher than normal still come in under the required spec.
combined with timing polishing an matching  on the usual places my tugger goes like a rocket.
and if hypowasitly speaking the guy with the Mk2 8v (badged as a 16v) wants me to own him down the Mad Mile again then it will be 3-0 to me :wink:
Cam: £10
Belt Kit: £25
Grinding: Lunch break
Fitting: Saturday morning
discovery of another hole in the floor: Priceless  :laugh:
Offline axewielder
  • 95 dragon 8v
« Reply #8 on: 21 January 2010, 13:51 »
so youve got a proper cylinder grinder with centres or whatever theyre called at work>? what do you do?
VW BUSH
« Reply #9 on: 23 January 2010, 18:13 »
jones and shipman Universal with three foot centres,
I am now a Tooling Engineer for a large medical moulding company responsible for new moulds/machines and all the bolt ons
at the time of the op i was Manager of a large toolroom with full cnc and manual equipment (still have access :wink:)
 :smiley:
