Author Topic: Mk3 Indicator Relocation  (Read 3158 times)
Offline lambogolf
Re: Mk3 Indicator Relocation
« Reply #10 on: 18 January 2010, 16:20 »
well there is a 'spare'hole there where they are replicas of the mk4.
you know the crappy universal side repeaters you get from motorworld? got one of those which plugged straight into the original slot in the front indicator and the plugged the bulb in. it worked... but... it was flashing fast where the bulb is a hell of alot smaller!
Offline robz
« Reply #11 on: 18 January 2010, 16:21 »
long shot - is it earthing properly??
whats it doing when ya put the hazards on???
does it flash properly then or not at all??
Offline lambogolf
« Reply #12 on: 18 January 2010, 16:23 »
where i only did 1 indicator it flashed normally with the hazards on...
it flashes as if there is no bulb there...
« Reply #13 on: 18 January 2010, 16:27 »
Simple problem, bulbs are too small, you need to run the standard bulbs, side repeaters will not do the job and are too low a wattage, from memory they are only 5w.
Offline lambogolf
« Reply #14 on: 18 January 2010, 16:28 »
the Standard bulbs will no where near fit into the headlights.. they are huge...
« Reply #15 on: 18 January 2010, 16:33 »
Hence why I said they are not designed to do what your trying to do, standard bulbs are 21w each, you have now switched to a pair of bulbs which total 10w.
The only idea I can suggest is to have a look at some of motorbike led ones on ebay which should cure the problem.
Offline lambogolf
« Reply #16 on: 18 January 2010, 16:41 »
that is not a bad idea.. so i basically need to get 2 orange bulbs that are 10.5w each?
Offline robz
« Reply #17 on: 18 January 2010, 16:41 »
hope ya get something found m8!!
make sure ya update the thread with what ya find and your solution, should help people in the same situation sort it too in the future!
Offline lambogolf
« Reply #18 on: 18 January 2010, 16:43 »
I hope to do a project thread on this as this sorta thing is not seen very often! just lookin through ebay for some bulbs now...
« Reply #19 on: 18 January 2010, 16:52 »
No 21w each
