Author Topic: Overheating Mk 4  (Read 1402 times)
Offline magpie26
Overheating Mk 4
« on: 18 January 2010, 08:47 »
Hi,
i have a mk 4 which suddenly decided to overheat (max. temp) at the weekend. Had a look under the bonnet with the engine running - water is clean but bubbling over the tank, fans arent working at all, the radiator isnt too hot to touch and there was also no loss of power. Think it may be the thermostat and hoping the head gasket hasnt gone but got to have another look tonight, any ideas?
Offline Rhyso
Re: Overheating Mk 4
« Reply #1 on: 18 January 2010, 08:59 »
Welcome  :smiley:
is there coolant pumping around the system?
Could be your water pump - they tend to fail for a pass time sadly  :sad:
Offline magpie26
« Reply #2 on: 18 January 2010, 09:15 »
Thankyou!
Im not sure as unfortunately, i only managed to get a quick look at it, will make sure i check later. Thanks for your help
Offline burnt01
  • We'll get it working
« Reply #3 on: 19 January 2010, 02:07 »
try removing the coolant cap cleaning both cap and bottle then do it back up.  A friends "just bubbled over" and it because the pressure was escaping through the cap and the water didnt circulate.  Therefore the heat didnt get too the thermo switch for the fan or even get to the radiator  :shocked:
we had a spare bottle though
Offline roger1234
« Reply #4 on: 19 January 2010, 14:47 »
I would start with the thermostat.
Offline vwdan80
« Reply #5 on: 19 January 2010, 18:41 »
Hi what engine do you have?  :smiley:
Offline gtibarnesy
« Reply #6 on: 23 January 2010, 16:26 »
take the small pipe off the coolant bottle and start the engine, give it a little rev and coolant should come out.  If it doesn't sounds like a shagged water pump if coolant does come out the thermosat is probably stuck closed.
