Golf mk2
rear jacking point/chassis repair panels..
Topic: rear jacking point/chassis repair panels.. (Read 2395 times)
golfnut8v
17 January 2010, 21:19 »
is there such a thing?
if so where do i purchase them..?
thanks..
mk2 golf gti 1990..
Last Edit: 18 January 2010, 10:08 by golfnut8v
maxp
J reg 8v digi gti
Re: rear jacking point repair panels..
17 January 2010, 22:50 »
Jacking point covers?
If thats what you mean you can still get them from vw for a fiver each.
golfnut8v
Re: rear jacking point/chassis repair panels..
18 January 2010, 10:10 »
i have just changed the title...
on the rear chassis,just at the jacking point,it has been damaged over the years due to use...the underseal has come off and now its rotten,will have to be cut out...so looking for a repair panel...any ideas..
thanks
dan_apps
too low for british roads!
18 January 2010, 10:39 »
how bad is the rot? a good welder should sort with just flat steel!
Breaker
Guest
18 January 2010, 15:46 »
http://bap.dominohosting.biz/members/bap/bapdb01.nsf/$$ViewTemplate%20for%20MakeModel!OpenForm&RestrictToCategory=VOLKSWAGEN%20GOLF%20%2809/83-02/92%29
golfnut8v
18 January 2010, 18:11 »
added this picture..
thanks for the reply regards beever panels...think this item is for the upper/inside the boot repair panel..
this is the lower chassis section at the rear of the car,flat area behind sill,has the rear beam attached to it....hope this nakes it clearer..
thanks
OakeyDoak16v
Reply #6 on:
19 January 2010, 03:15 »
Weld a large plate over that mate.
Golf mk2
