Author Topic: knocking  (Read 2220 times)
Offline gtieng
knocking
« on: 17 January 2010, 17:16 »
hi ppl getin a knocking noise coming from front of drivers side been and had it put up on the ramps there is a slight movement coming from ball joint and slight movement in passanger side wishbone arm  can any one tell me wat could be knocking pls
jamie16v
Re: knocking
« Reply #1 on: 17 January 2010, 17:22 »
worn ball joint and bushes. quite possibly the anti roll bar bushes too!
Offline gtieng
Re: knocking
« Reply #2 on: 17 January 2010, 17:24 »
roll bar bushes are fine
Offline kniterider
  • had most, sold most and often buy more!
Re: knocking
« Reply #3 on: 17 January 2010, 17:26 »
more than likely the worn ball joint youve mentioned , if your anitroll bar bushes are ok
 :smiley:
Offline gtieng
Re: knocking
« Reply #4 on: 17 January 2010, 17:29 »
theres a slight tear in the ball joint rubber could that still make it knock
Offline kniterider
Re: knocking
« Reply #5 on: 17 January 2010, 17:34 »
well the tear in the rubber boot isnt going to make it knock but if there is excess play in the joint its self because it got dry and worn then it could cause a knocking noise , if its worn id replace that first as its going to need doing come mot time anyway , if the knocks gone it was that, if not check antiroll bar bushes / wishbone bushes and shock / top mount etc.... also worth checking trackrod end and tie rod from steering rack for play as these could also give a 'knock' effect when going over bumps etc
Offline gtieng
Re: knocking
« Reply #6 on: 17 January 2010, 17:58 »
 il replase the ball joint tomorrow are they pain in arse do
Offline kniterider
Re: knocking
« Reply #7 on: 17 January 2010, 18:17 »
never changed one on a mk4 before, done mk2/3's and there easy i doubt the mk4 will be too different from earlier models?? just need a good jack , axle stand , a bar to lever down and out of hub carrier and sockets / spanners... and of course a new ball joint.
should only take an hour if your pretty mechanically minded.
Offline gtieng
Re: knocking
« Reply #8 on: 17 January 2010, 18:25 »
il give it a go n hope for the best
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: knocking
« Reply #9 on: 17 January 2010, 18:56 »
ball joints are an arse, the CV joint is in the way
