Author Topic: Cutting out??  (Read 1073 times)
Offline whiter_than_white
  • Seize the day or die regretting the time you lost!
Cutting out??
« on: 17 January 2010, 11:39 »
my mk3 gti 8v AGG has started cutting out when i'm declerating  :sad: i have just removed the air intake pipe to clean the throttle body to see if that would cure it but it was mint inside?? the intake pipe is split tho and has been taped up by a previous owner, would this cause cutting out?? if not what could it be?? it does it when hot or cold but doesn't do it all the time, its just when changing down gears, dip the clutch and it just cuts out
any help would be much appreciated
Offline Deano2711
  • 1992 VR6
Re: Cutting out??
« Reply #1 on: 17 January 2010, 12:03 »
The split intake pipe is not going to help. However I would remove and clean the throttle body as mine looked clean until I removed it. Cleaned it up and the problems stopped for me.     Cheers     Deano
Offline alirkhan
Re: Cutting out??
« Reply #2 on: 17 January 2010, 12:31 »
dude..dunno about 8vs but my vr6 has an idle noise damper and wen it went, the engine started cutting out wen the rpm was low...worth a check..see the following post..
http://www.golfgtiforum.co.uk/index.php?topic=140248.0
lets c if i can sav an ass
Re: Cutting out??
« Reply #3 on: 17 January 2010, 14:04 »
got an intake pipe coming from a local scrappy, will take off and clean tho, cheers deano  :smiley:
