Author Topic: Wet Boot  (Read 9630 times)
Offline zdebx
Wet Boot
« on: 16 January 2010, 16:50 »
The boot carpet in the right corner, behind the offside rear light got wet after the rain...It hasn't spread around the whole boot, so I want to stop it, before it gets too bad.
So where's the water coming from? My first thought is the aerial?
My Golf mk3 1.8 SE is FOR SALE - Jetex exhaust + Jamex coilies & More...Only £550! More info here > http://www.golfgtiforum.co.uk/index.php?topic=161711.0
Offline Andy-H
Re: Wet Boot
« Reply #1 on: 16 January 2010, 16:54 »
I would check the seal around the back of the light hasn't got damaged Mate  :smiley:.
'02 A4 Quattro sport - gone
'91 Tornado red Mk2
Offline whiter_than_white
  • Seize the day or die regretting the time you lost!
Re: Wet Boot
« Reply #2 on: 16 January 2010, 17:04 »
yeah i'd be sorting a new seal for that light unit first, if you cant get one then a tube of silicon is always a winner
Offline zdebx
Re: Wet Boot
« Reply #3 on: 16 January 2010, 17:36 »
I remember, when I put the new lights, the seal was ok, but I will check tomorrow anyway.
Offline zdebx
Re: Wet Boot
« Reply #4 on: 17 January 2010, 13:07 »
Check the rear offside light, and everything seems ok. What else should I look for?
Offline boneybradley
  • Back in a Mk3...
Re: Wet Boot
« Reply #5 on: 17 January 2010, 13:43 »
lights,aerial and boot seal.....but i recon lights and i solved this before by using 2 seals (my after market one's by fk didn't seal correctly so I used the o.e one's too)
Offline zdebx
Re: Wet Boot
« Reply #6 on: 29 January 2010, 21:55 »
I doubled sealed the offside rear light last weekend, but it rained yesterday and it was soaking wet behind the light again  :tongue:
So I guess it's coming from somewhere else? Or could it be the aftermarket lights letting the water in? If that's the problem, why is it only leaking on one side? The nearside is ok.
Where's the boot seal?  :shocked:
Re: Wet Boot
« Reply #7 on: 29 January 2010, 23:46 »
Have you got a sunroof if so then check the drain tube in that corner, if not then I would suspect your taillights, the pattern ones can let in water.
Offline zdebx
Re: Wet Boot
« Reply #8 on: 30 January 2010, 11:13 »
No sunroof, so I will change the tail lights back to standard GTI smoked ones and see if that solves the problem.
Cheers :)
Offline Khare
  • The bear that khares
Re: Wet Boot
« Reply #9 on: 30 January 2010, 11:37 »
It will be the tail light dude, especially if the patch is just underneath the cluster.
