Author Topic: Gear shift repair kit fitting??  (Read 1132 times)
Offline DMc-GT/GTi
« on: 16 January 2010, 15:41 »
I have got a repair kit for the Anni, but i don`t know how to fit it.
I have had a look under the gear lever trim and can`t work out how the lever gets past the linkage, the new bits look easy enough to fit when the lever is out of the way. Am i missing something obvious? I presume it is all done from the drivers seat?
Anyone done one of these recently to advise :sad:
Offline DMc-GT/GTi
Re: Gear shift repair kit fitting??
« Reply #1 on: 16 January 2010, 21:01 »
Anybody?
Offline Cable
« Reply #2 on: 17 January 2010, 00:36 »
8v or 16?
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 17 January 2010, 12:31 »
rubjonny has done a guide in the mk2 maintenance section and the mk3 is fairly similar (the 8v is 99% the same to fix and I'm sure the 16v is similar)
« Reply #4 on: 18 January 2010, 11:51 »
8v is similar, 16v, TDI and VR6 completly diffo as they're cable shift :)
