Author Topic: mk3 golf gti clutch problems!!  (Read 11168 times)
Offline Deano2711
  • 1992 VR6
Re: mk3 golf gti clutch problems!!
« Reply #10 on: 14 January 2010, 20:57 »
took me 20 minutes but only becase I had trouble jacking the gearbox arm up, kept slipping off the jack.
I also used the jack.....thought I was the only cheat  lol   Still at least I found a use for the standard Mark 3 jack as it won't jack the bloody car up !!!!!!!!!
« Reply #11 on: 14 January 2010, 20:58 »
I had to remove the wiper linkage on mine, could see no other way.
Offline Khare
  • The bear that khares
« Reply #12 on: 14 January 2010, 20:58 »
Also took me a while removing the screws on the scuttle panel!
Offline Deano2711
  • 1992 VR6
« Reply #13 on: 14 January 2010, 21:00 »
I have to take mine off again this weekend as my footwell has been leaking in recently.....cleaned out the gutters last week and thought I had cured it but it's back. I think it might be the rubber bung around the clutch cable as I had a bit of trouble re fitting this. Anything else it could be though??
Offline Khare
« Reply #14 on: 14 January 2010, 21:06 »
either the rubber bung on the clutch cable or on the accelerator cable. Put some vaseline around the bungs.
Offline Deano2711
  • 1992 VR6
« Reply #15 on: 14 January 2010, 21:07 »
Cheers Buddy
Offline Khare
« Reply #16 on: 14 January 2010, 21:11 »
no worries mate, good luck  :smiley:
« Reply #17 on: 15 January 2010, 08:57 »
the trick to the self adjusting cable is you compress it using the white clip thats flopping loose on the cable, you shouldnt need to jack it up the clutch arm.
though if the clip above is missing you would have to jack up the arm or chop the cable.  compressing the cable like this resets it so in theory it should work again with a new clutch, but they often just break so never work right, new one is required in that case. I would always put  a new cable on as a matter of course anyway
Offline qwaszxl
« Reply #18 on: 15 January 2010, 18:13 »
Thanks for the info guys, going to give it a go tomorrow and see how it goes. Will let ya know how I get on!
Offline boneybradley
  • Back in a Mk3...
« Reply #19 on: 15 January 2010, 19:57 »
I will say...tie some thick string around the cable (where it clips to the pedal) when removing and pull the cable through to the engine bay...and reverse this when refitting the new cable as it makes life so much easier threading the cable through the bulk head (which can take time/good aim!)
