Author Topic: Best oil for Gti and airbox pipes  (Read 7076 times)
Offline 95gti8v
« on: 12 January 2010, 21:33 »
need to do an oil change and wondering what best for an 8v?
I normally use Duckhams Mineral 15/40 on my other veedubs would this be ok?
Also i got the original airbox to replace the K&N, does anyone have a pic of engine bay with where hoses etc would go?
Cheers  :smiley:
Offline javalin
Re: Best oil for Gti and airbox pipes
« Reply #1 on: 13 January 2010, 11:33 »
get the VW stuff - I think its 5 or 10/40?
removing an induction kit?  Simple enough, one hose to manifold, warm air hose (if you have one) to the bottom bit under the manifold, and the airbox input goes into the side panel.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline AudiA8Quattro
« Reply #2 on: 13 January 2010, 11:42 »
What's the mileage and age?
Offline Saville
« Reply #3 on: 13 January 2010, 11:44 »
there is a pic of the engine bay under a topic called common problems, just search for mk3 common problems
Offline javalin
« Reply #4 on: 13 January 2010, 11:49 »
it doesn't really show the airbox pipes though.
Offline axewielder
  • 95 dragon 8v
« Reply #5 on: 13 January 2010, 13:07 »
i wouldnt use ant less than semi synth on a mk3 or even mk2, i just got 20L of Quantum(VW) fully synth think its 10/40 for £60 off of TPS(http://www.thetradepartsspecialists.co.uk/) its cheap + decent quality
Offline 95gti8v
« Reply #6 on: 13 January 2010, 19:47 »
95 mate with 104k  :smiley:
Cheers guys i'll have a nosey at the airbox at weekend hopefully get it fitted.
« Last Edit: 13 January 2010, 19:57 by 95gti8v »
Offline b1gdub
  • MK4 1.8T AGU
« Reply #7 on: 13 January 2010, 20:33 »
Standard 10w40 mate.
Offline 95gti8v
« Reply #8 on: 25 January 2010, 22:23 »
So a semi synthetic 10/40 would be best then?
Have a couple of relatives in the trade so it probably won't be VW quantum, be duckhams or comma
 :smiley:
