Author Topic: 280mm brakes  (Read 1027 times)
Offline DubJoey
280mm brakes
« on: 12 January 2010, 20:16 »
off what cars can you get the hubs that will carry the 280mm brakes got everything else just need the hubs will any mk3 fit cos i come across these quite a bit but not sure which ones if any i can use
cheers
Offline Reasty
  • Alpine white valver.
Re: 280mm brakes
« Reply #1 on: 12 January 2010, 20:53 »
You will need the hubs from either a golf or corrado 16v/ g60,which you can sometimes find on ebay for a reasonable price,not so sure if the mk3 hubs fit (i take it your putting them on a mk2 gti?) but im sure someone will be along to confirm shortly. :smiley:
« Last Edit: 12 January 2010, 21:08 by Reasty »
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: 280mm brakes
« Reply #2 on: 12 January 2010, 20:55 »
Mk3 ones the balljoint is off centre compared to the mk2 iirc. its slightly further back..
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline richard s
Re: 280mm brakes
« Reply #3 on: 12 January 2010, 20:59 »
mk2 golf 16v/corrado/seat ibiza cordoba toledo and i think passats also
just check that the hub doesnt already have the brake caliper carrier built in and they should be ok
do a search and you should find all the info for this
Offline Mew
Re: 280mm brakes
« Reply #4 on: 12 January 2010, 21:04 »
I thought that you could use mk3 hubs as long as they're from a 4 stud model with 256mm brakes :undecided:
Re: 280mm brakes
« Reply #5 on: 13 January 2010, 11:27 »
yeah MK3 4 stud ones are same as MK2, just as above needs to have at least 256mm brakes. MK3 cabbies a prime source for these, starting to see these often in scrappies now
Offline DubJoey
Re: 280mm brakes
« Reply #6 on: 13 January 2010, 19:45 »
ok thanks off to scrapy this weekend so now i no what to look for
Offline Diamond Hell
  • Opinions я Us
Re: 280mm brakes
« Reply #7 on: 13 January 2010, 23:06 »
There's a lot of Passats and SEATs out there with 256mm and 280mm brakes fitted to them, just the same as G60s.
