Author Topic: intermittant starter  (Read 1843 times)
Offline Adam-D
« on: 20 October 2004, 18:39 »
my golf.
i got a new battery on it, it was 400 odd amps crank so a little low and car wouldnt turn over
so i attached jump leads to my cav and revved it and my golf fired up  ;D
so i let it run upto temp etc all fine :D
then went to re-start it to put it in garage later with cav again and it made a mad noise like the starter was stuck and then it didnt do anything?
is my starter shot?
1.8 16v btw  ;D
Offline adyh
Re: intermittant starter
« Reply #1 on: 21 October 2004, 09:22 »
Might be stuck , put the car in reverse and rock it backwards , this should release the starter motor.
Offline davidhawkins_78
  • Valver Bad Boy
« Reply #2 on: 21 October 2004, 10:15 »
Sounds like the solenoid - when you went to start the car the second time did u check the battery's charge as it might be goosed - or something else in the system is, and it's not getting a charge.
Start the car at night and go for a good spin and check the battery - leave it over night and check the battery again. I bet you'll find a difference  ;)
Then if that's the case check the other components are working correctly before running out to buy a new battery as it's often not at fault !
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline Adam-D
« Reply #3 on: 21 October 2004, 10:58 »
2nd thing im not sure the alt is wired up properly  ???
its a brand new alt but theres a blu wire not conected to anything  ???
mind you theres wires all over the place not connected to stuff
also my temp gauge doesnt work
  • Valver Bad Boy
« Reply #4 on: 21 October 2004, 11:10 »
Sounds like you need to find them a home as other than the spot light loom there shouldn't be any 'spair' wires under there !
Offline Gambit
« Reply #5 on: 21 October 2004, 11:16 »
on the coolant one
there is three senders round the water outlet elbow on the side of the block
all three senders are just temp senders so can be interchanged to test them
Red/Yellow wire - dash temp gauge
Red/Green wire - ISV/Cold Start
Blue/White wire - Ignition ECU
u can test the ISV by simply feelin it with the ignition switched on. you should feel a buzz on touching it
MFA oil temp is the green wire on the back of the head
Offline Adam-D
« Reply #6 on: 22 October 2004, 23:09 »
right
ill check cold start
the mfa works
ill check the other one cos it must be that one
red/yellow wire
as for the alt i need someone with same engine as me
ill get the color of the loose wire i think its blue thou
