Author Topic: help me please engine trouble ?????????????  (Read 1988 times)
Offline djdeekers
« on: 11 January 2010, 18:02 »
can anyone help me please???????????????
i bought a golf a few weeks ago 1.8 gti 20v - and the other day when i was driving to work the car just stopped dead - its turning over but wont start, - the timiing belt and all is still in place, but my mechanic says there is a timing chain on the golfs as well and that, and he thinks it may have came off the tensioner - if this is the case, would there be valves and all bent? - would it be better to go on down and take the whole head off and see - or maybe replace the tenisoner and fire it up first to see if it goes ok
what should i do ?
any help much appreciated
« Last Edit: 11 January 2010, 18:17 by djdeekers »
Offline madgti
Re: help me please engine trouble ?????????????
« Reply #1 on: 11 January 2010, 18:12 »
hello
Offline djdeekers
« Reply #2 on: 11 January 2010, 18:16 »
can u help me out lad
Offline madgti
« Reply #3 on: 11 January 2010, 18:45 »
sorry dude cant really advise . bjut i think i'd try the tensioner first . someone will be along soon enough and help you
Offline Alec
« Reply #4 on: 11 January 2010, 19:27 »
I thought it was only the VR's that had a chain? Post this in the mk4 section mate and I bet you will get a quick response
Offline MrBounce
  • Bora TDi 130 Highline - usually filthy.
« Reply #5 on: 11 January 2010, 19:56 »
Greetings and Salutations  :cool:
Keeping schtum. Mostly.
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 11 January 2010, 19:58 »
Welcome to the site.  :smiley:
Your car has a cam belt and not a chain.
think he's talking about the chain between the two cams.. but if that had snapped while you were driving you'd have heard a hell of a racket! Get someone to scan the car for fault codes. A failed crank position sender (vw call it the impulse sender - a fault code reader may refer to it as an engine speed sensor) can cause this and won't always put the engine management light on.
Offline roger1234
« Reply #7 on: 12 January 2010, 16:43 »
Welcome.  :smiley:
Offline GOLF_STU
  • THE_GIT
« Reply #8 on: 12 January 2010, 22:32 »
welcome along  :smiley:
V TEC KICKED IN Y'ALL!!!
Offline djdeekers
« Reply #9 on: 13 January 2010, 13:04 »
So if I change this sensor do u think the car will be ok to drive again , would there be any valve damage
