Author Topic: What need doing with this code, HELP!!!!!  (Read 1055 times)
kcolevol
« on: 10 January 2010, 22:58 »
Car engine light came on due to my de-cat, have to reset it every now and then but got this code twice now which is different, P1325 or 17733 Knock control limit attaind. WTF??  What needs fixing lol.
Offline topher
  • Administrator
  • fully functioning
Re: What need doing with this code, HELP!!!!!
« Reply #1 on: 10 January 2010, 23:04 »
When did you last change your spark plugs?
kcolevol
« Reply #2 on: 10 January 2010, 23:11 »
Service before last, only about 8000-10000 miles.
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 10 January 2010, 23:15 »
damn, that would've been the simple one to rule out :grin:
that code is specific to cylinder #1 .. wouldn't hurt to pull the plug out just to check it's condition.
kcolevol
« Reply #4 on: 10 January 2010, 23:21 »
Yeah can do.  Is there such sensor a a knock sensor but on each cylinder?  Engine runs fine by the way, just lose power (safe mode) when i get this code.
Offline topher
  • Administrator
  • fully functioning
« Reply #5 on: 10 January 2010, 23:23 »
The knock sensor is doing it's job, but it can only adapt so far before it reaches it's limit. Usually it's a spark plug or coilpack that causes this - try swapping coilpacks 1 & 2 over and see if the fault code goes over to the next cylinder too.
kcolevol
« Reply #6 on: 10 January 2010, 23:29 »
Good idea, ill get some new plugs tomorrow anyway coz i like to keep them fresh lol, ill swap the connectors like you said and see what happens, cheers mate.
Offline topher
  • Administrator
  • fully functioning
« Reply #7 on: 11 January 2010, 00:57 »
swap the coilpacks not the connectors!
