Author Topic: Can anyone HELP?  (Read 792 times)
Offline leeroy86
Can anyone HELP?
« on: 10 January 2010, 18:56 »
I was down at R - Tech on wednesday having a k03s map. My car is a AGU with a k03s and forge tip. The car was only boosting 18 psi and it should be around 20-22 psi.
The guys had a good look around and couldnt find anything wrong and come to the conclusion it's probably the actuator that needs adjusting. The k03s come off a seat ibiza and has done 40k miles but was checked out by a turbo specialists in wakefield before I bought it at a cost of £25 + vat. They said it was perfect. I mention this just to give you guys a little info before answering my question.  :wink:
Now my question is when im hitting full boost in any gear there is a whining noise that sounds like its coming from the turbo. COULD THIS BE DUE TO THE ACTUATOR NOT BEEN SETUP CORRECTLY AND THE WASTEGATE NOT OPENING/CLOSING PROPERLY? Nick at R - tech drove the car whilst it was making this noise but didnt even mention it.  :grin:
Anyone got any ideas?
cheers
Lee
« Last Edit: 10 January 2010, 19:14 by leeroy86 »
Offline topher
  • Administrator
  • fully functioning
Re: Can anyone HELP?
« Reply #1 on: 10 January 2010, 19:33 »
Didn't hear it on the rollers dude.. but then you can't hear much when they get spinning! It's not coming from the gearbox is it? :undecided: Those were never really designed to rev much above 4000rpm
The actuator venting the wastegate shouldn't really make a whining noise, but you will hear an elevated turbo whistle/whoosh.
Offline leeroy86
« Reply #2 on: 10 January 2010, 19:57 »
Il take you for a spin in it before you start work on it when I come down next. I dont think its the gearbox mate, the noise seems to be coming from the turbo area.
Im going to book in for NEXT week I think.
Im sure the car will be running spot on after the next visit  :wink:
« Last Edit: 10 January 2010, 19:59 by leeroy86 »
