Author Topic: Ordering stuff from GSF.. Can anyone see anything wrong?  (Read 1701 times)
Offline jamie_pyrite
The car is a 1991 H reg 16 valve with power steering.
Part Number           Description           Fitment           Price(£)           Quantity           Delete
13330D       FAN/POW.STEER.BELT-10x630       G2 16V 10/90 >10/91 +AC         2.50       1       Delete
71566B       CLUTCH CABLE-SELF ADJ.       G2 16V 2/86 >10/91         17.50       1       Delete
13346       FAN/POW.STEER.BELT-10x735       G2 PAS Belt         2.50       1       Delete
73217       PEDAL RUBBER-CLUTCH/BRAKE       G2 8/83 >7/92         0.60       2       Delete
MMC3474       AIR FILTER-BQ       G2 16V 2/86 >7/89         4.90       1       Delete
11640       DIPSTICK GUIDE       G2 16V 2/86 >10/91         1.00       1       Delete
17832B       HEATER MATRIX       G2 8/83 >7/92         37.80       1       Delete
13140       TIMING BELT TENSIONER       G2 16V 2/86 >10/91         21.00       1       Delete
87597A       PARCEL SHELF STRAP       G2 8/83 >7/92         1.35       2       Delete
13109       TIMING BELT       G2 16V 2/86 >10/91         13.50       1       Delete
MMWK853/1       FUEL FILTER       G2 1.8 16V 86>92 KR Eng.         10.90       1       Delete
R-3000963001       CLUTCH KIT-SACHS SPORTING       G2 1.8 16V 2/86 >10/91
113.00       1       Delete
10142A       ENGINE MOUNTING-FRONT       G2 16V 8/87 >7/88         12.00       1       Delete
MMW719/5       OIL FILTER-MANN       G2 Petrol (Not G60) 8/83 >7/92         2.30       1       Delete
18600       VAC HOSE       General Use         2.00       1       Delete
01159       CYLINDER HEAD BOLT SET       G2 1.8 16V 2/86 >10/91         17.20       1       Delete
11142       CYLINDER HEAD GASKET-BQ       G2 16V 2/86 >10/91         9.00       1       Delete
TOTAL(exc. VAT & Delivery)          £ 271.00
As well as a few little parts that I need, I'm ordering parts for doing a head gasket, heater matrix and clutch change. I figured while they were off I may as well stick a new front engine mount on, change all the belts and the cam tensioner.. Have I missed anything else that I should order? I've ordered a head bolt set to go with the head gasket.. is there anything else needed?
I'm handing all the parts over to my guy who is doing the work so need to make sure things are right! :)
Thanks!
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: Ordering stuff from GSF.. Can anyone see anything wrong?
« Reply #1 on: 08 January 2010, 16:55 »
Theres a few things there youve got that are pre 90 amongst other things..
ill send you a pm regarding it in a short mo
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline Khare
  • The bear that khares
« Reply #2 on: 08 January 2010, 17:00 »
I'd get the bits from VeeWservice. http://www.veewservice.com/
Tis were Beavis works and they have very good competitive prices + with Beavis yu will know that all the parts are right and will fit your car.
« Reply #3 on: 08 January 2010, 19:28 »
Cheques in the post :grin:
Quote
« Reply #4 on: 08 January 2010, 19:30 »
Just a though as all of that is coming off.. You're going to want a rocker cover gasket set as well.. and inlet and exhaust gaskets as the fanimolds will be coming off! cam seals could also be an option and water flange seals.. the head gasket set with all that in isnt too much over the top of buying the head gasket alone and will see you fit to have everything you would possibly need - or maybe an odd couple of bits left over!
Quote
Offline weazgti
« Reply #5 on: 09 January 2010, 00:05 »
valve stem seals in a headgasket kit. They re only pennies from gsf anyway but as mentioned above, you might aswell pay the little extra and get the whole lot done.
I had the right idea got the lot from partco then took the head off and realised i bought a ohv valve spring compresser. What a c*ck.
Luckily mine doesnt smoke now,think it was because some one had put bout 12 bottles of rad weld in so all the waterway holes were blocked solid aswell as the breather hose. Should of taken a pic of the gasket it was unbeleivable.
