Author Topic: Cam Belt Cover  (Read 1147 times)
Offline th3_f15t
Cam Belt Cover
« on: 08 January 2010, 11:22 »
I have a PB engine in my Mk2 GTi 8v. I'm about to replace the cam blet, but I can't figure out how to remove the lower part of the cam belt.
It appears to wrap around the lower pulley, which is help in by 4 allen keys. Do you need to remove the pulley to get the cover off?
Moving over to Flickr, sorry for the broken picture links!
Re: Cam Belt Cover
« Reply #1 on: 08 January 2010, 11:45 »
Yes, the needs to be removed.
Re: Cam Belt Cover
« Reply #2 on: 11 January 2010, 09:26 »
dont undo the middle 19mm 12point bolt tho, the pulley is only held opn with the 4 allen bolts.
they can be pretty well stuck on though, so you might need a puller to get it off
Offline Diamond Hell
  • Opinions я Us
Re: Cam Belt Cover
« Reply #3 on: 11 January 2010, 13:31 »
Make sure you attack the allen head bolts properly, too.  They'll often be seized and need a hand operated impact driver (not an airgun) to shock them loose, rather than round them out.
