Author Topic: brake bleed Q.  (Read 1409 times)
Offline braderz
brake bleed Q.
« on: 07 January 2010, 00:25 »
began the gunsons eezibleed procedure earlier today as brakes are a bit spongy, got all setup, but i could not get the bleed nipple open on the right rear. The procedure says to start here so did not try any others. What can i do!? When i was doing this i left the handbrake off, does it need to be on, im going to try again with the wheel off but i wanna get it right before setting it all up again!
Offline roger1234
Re: brake bleed Q.
« Reply #1 on: 07 January 2010, 09:52 »
Put plenty of release fluid on the nipple and careful you don't snap it.  :smiley:
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
Re: brake bleed Q.
« Reply #2 on: 07 January 2010, 22:05 »
 Lots of penetrating fluid required, leave for a few hours to work. what car is it?. On some you have to clamp the bias valve open on the rear axle.
Offline AudiA8Quattro
Re: brake bleed Q.
« Reply #3 on: 07 January 2010, 22:07 »
Don't use a spanner, try undoing it will a small 1/4 inch rachet and socket, you will be applying pressure more centrally.
Offline gazpowells
Re: brake bleed Q.
« Reply #4 on: 10 January 2010, 16:42 »
+1
Offline braderz
Re: brake bleed Q.
« Reply #5 on: 15 January 2010, 00:19 »
its a '99 gt tdi, whats a best fluid to use on that then? ive yet to try again as next time im taking wheel off for better access
