Author Topic: Quick query - bolt size for 16v carriers  (Read 761 times)
Offline jmsheahan
« on: 06 January 2010, 14:11 »
Hi all,
Very quick query - does anyone know the size of the 2 bolts that hold a 16v 256 carrier to the hub?
Offline ben harcombe
Re: Quick query - bolt size for 16v carriers
« Reply #1 on: 06 January 2010, 19:59 »
i bought sum not long back from vw and they were very cheap for main dealer instead of finding replacements like me which is a head ache in itself
Unless you want to know for a different reason sorry mate
Offline jmsheahan
« Reply #2 on: 06 January 2010, 20:06 »
Cheers, rang the stealers earlier, 70p a bolt IIRC, or £2 for a 35mm one. They weren't sure on the size either. Annoyingly I don't have the carriers to hand to check.
£1.50 per bleed nipple cover (on backorder too), and £9 per slider pin :shocked: I'll be making do with what I have, just need those 2 bolts for each side.
« Last Edit: 08 January 2010, 14:33 by jmsheahan »
Offline jmsheahan
« Reply #3 on: 08 January 2010, 14:33 »
Anyone happen to know if I can just rob the ones from a 239 setup?
edit- they are 17mm. Sorted now  :smiley:
« Last Edit: 08 January 2010, 14:39 by jmsheahan »
