Author Topic: Air intake loose GTI MKV  (Read 7835 times)
Offline funkythumbs42
« on: 05 January 2010, 22:05 »
I opened my bonnet today to find my air intake had came loose from where it goes into the engine, i reattached it went for a drive and it has blown loose again exactly as it did before.
Has anybody else had this problem?  How should it fix onto the engine?  I cant see any kind of clip or anything?  Should i be worried about this?
Greg
Re: Air intake loose GTI MKV
« Reply #1 on: 05 January 2010, 22:09 »
Im sure you know what part i mean but just in case:
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 05 January 2010, 22:14 »
I can clearly see a clip in that picture securing it.. is yours missing?
« Reply #3 on: 05 January 2010, 22:16 »
im useless with stuff like this lol
i can see the clip but it isnt facing up at the top its to the right at the side
how could this have came loose?
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 05 January 2010, 22:24 »
Engine movement maybe. It's just a spring clamp. You need to pinch it together with pliers/grips so you can open it up enough to sleeve the intake pipe back onto the engine cover, then secure the clamp where the two overlap.
« Reply #5 on: 05 January 2010, 22:25 »
aha i see!! thanks for that i'l give it a whirl tommorow and let you know how i get on!!
Greg
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 05 January 2010, 22:26 »
Watch your fingers, those suckas can bite :wink:
« Reply #7 on: 05 January 2010, 22:31 »
with this loose should i expect to loose performance or fuel economy as i didnt really notice much difference with it blown off?
Offline topher
  • Administrator
  • fully functioning
« Reply #8 on: 05 January 2010, 22:40 »
The air mass meter is behind that so you dont have to worry about unmetered air in the system.. i guess the only real issue is it might be sucking in slightly warmer air from around the engine bay - but the ecu monitors intake temperatures and makes adjustments to suit. It might be a tad noisier but there will be no harm done.
Offline jaydubveedub
« Reply #9 on: 06 January 2010, 12:17 »
It shouldn't be coming off if the spring clamp is fitted, those things are as tight as a nuns....
As above, watch your fingers when fitting/removing it as it f*cking hurts when it snaps on your finger. I know this.
2003 Passat 1.9 Sport TDI Wagon | Inky Blue | Lots of Wax
