Author Topic: Rear brake pads  (Read 1458 times)
Offline Primus84
Rear brake pads
« on: 04 January 2010, 14:14 »
What's the price for OEM rear brake pads?
How easy a job is it to replace em?
If I got em done at an indy how much including labour might I be looking at?
Cheers!
Offline FamilyDub
Re: Rear brake pads
« Reply #1 on: 04 January 2010, 15:23 »
Cheers!
Have you CALLED an Indy for their price, instead of asking us lot?  :tongue:
MKV GTI | Reflex Silver | 5-dr | Anthracite 17" | Manual | Highline MFD | Cruise | Revision 'D' DV | Dirty Pipes |
The GTD is like a blow up doll. The GTI is like a proper woman. Sure the doll might last longer, and the woman might have higher running costs, but which would you rather have?
Offline Primus84
Re: Rear brake pads
« Reply #2 on: 04 January 2010, 16:14 »
Just after an idea, someone on here must have had em done at some point.
Not had time to sit down and call an indy as yet.
Offline isitme
Re: Rear brake pads
« Reply #3 on: 05 January 2010, 13:02 »
Mine were about £90 for the rear axle (ie both sides changed) done by the local VW stealer. Not too bad as the pads were £27 each pair IIRC. I looked in to doing it myself and there are lots of guides on the net (some linked to from this forum if you do a search) but it needed a special tool to push the piston back in and I'm not that experienced so left it for some who knew what they were doing.
Offline bertmort8
  • 2.0gt fsi
Re: Rear brake pads
« Reply #4 on: 05 January 2010, 13:35 »
my car is just being serviced and is having the rear pads replaced.
60 quid fitted
wants a gt tdi
Offline ams_sxi
Re: Rear brake pads
« Reply #5 on: 05 January 2010, 14:22 »
i changed mine myself bought pads from euro car parts, easy to do, would be easier with the wind back tool but i just used adjustable spanner
