Author Topic: Interior lights dead how do i swap them ?  (Read 1663 times)
Offline Tom4388
« on: 03 January 2010, 23:09 »
i drive a mk3 and recently whilst driving at night i noticed that a couple of the green lights behind the heating and fan controls
had started to look a little dim, what i want to know it is it easy to get to the bulbs behind to swap them? and i thought whilst i'm swaping them maybe changing the colour of them is it easy to get hold of new bulbs and swap them ?
cheers
Offline patty
Re: Interior lights dead how do i swap them ?
« Reply #1 on: 03 January 2010, 23:24 »
just changed mine mate,
not that hard a couple of screws and your there.
it is only 1 light that does all 3 heater controls,it uses a plastic mirror kind of thing to project to all 3 controls.
you will see what im on about when you get there.
halfords sell the bulb aswell... it's a tiny little thing.
pat.
1996 black 5 dr 2.0 gti 16v
Offline Tom4388
« Reply #2 on: 04 January 2010, 19:20 »
cheers for replyin
i havent had a proper look yet but were about are the screws?
do halfrauds do the bulbs in different colours cos the green light looks poo lol
Offline patty
« Reply #3 on: 05 January 2010, 11:37 »
cheers for replyin
i took the ashtray out, as i was doing my vag com lead bit aswell.
there is a surround which goes around the dials, unclip this carefully,the screws are underneath that, you will see them straight away once the surround is unclipped.(4 ,i think)
and 2 behind the ashtray...if i remember right..lol
as for halfords doing different colour bulbs, i couldnt say, i was just chuffed they had the normal one in stock  lol
cheers
pat.
Offline Tom4388
« Reply #4 on: 06 January 2010, 12:02 »
right ...... lol
i had a look last night and i couldn't work out how to get it off :grin:
i'll have another look today.
cheers for the help the mk3 is my first car and i'm only just gettin into the golf 'scene' :nerd:
cheers
Offline Tom4388
« Reply #5 on: 06 January 2010, 12:24 »
i've had a look and i've got the four screws from the inside out but i dont know what to do next so i put it back together  :grin:
Also i dont know if this has happened to anyone but after i put it back together, went inside for a few hours and
came back out to go to the shop, i turned the fans on and its makin a weird ringin sound  :huh:
does anyone know what that could be? it sounds a bit like the fans hitting somethin as its spinnin around  :huh:
cheers
Offline patty
« Reply #6 on: 06 January 2010, 13:03 »
your nearly there mate. :smiley:
2 x screws behind the ashtray.........that should just pull out.
unclip the fan surrround to seel the 4 screws ....undo those.
unclip/pull out your rear window dimister.and any other switches you have..elec windows/ a/c ...and pull out the blanking ones aswell.
then it should all just wiggle out with a bit of luck.
enough for you to see the bulb you need to change........dont blink,you might miss it...lol
pat.
Offline Tom4388
« Reply #7 on: 06 January 2010, 17:18 »
cheers i appriciate the advice.
i'll give it a go when i get a replacement bulb sounds like hard work for a little LED lol
cheers
