Author Topic: Help needed with spring rates Geo setup etc for MK2 Track car  (Read 5403 times)
Offline s1monc
I am building a MK2 track car & need some advise with suspension & Geometry setup.
It will be a dedicated track car but will have an MOT, i want to get the best handling i can on track.
1. I am going to buy some Gaz coilovers from Rally design next week but what spring rates do people recommend bearing in mind the ones they sell with the kits are probably for road/track, my car will be track only so don't need any comfort.
2. I have a complete set of poly bushes already
3. I have a rollcage already which should stiffen things up a bit
4. Anyone recommend a descent front strut brace ?
5. I have read about underbody strut brace, do i need one & where can i buy one ?
6. What top mounts do i need, G60 or will it be better to get the fully adjustable type to adj camber, eccentric or concentric ?
7. I will be using 195/50/15 R888 on Team dynamics pro race 3 wheels
8. I will need to get the geo setup after its complete,corner weighting ?
All i want to do is get the car handling the very best i can on track with simple upgrades.
Simon.
VeeDubGTI16v
Re: Help needed with spring rates Geo setup etc for MK2 Track car
« Reply #1 on: 03 January 2010, 10:19 »
you are best off buying them direct from gaz, and ask their advice on spring rates. You will need to know corner weights or at least front and rear axle weights though, plus what tyre you will be using the most.
i doubt theres much difference in front strut brace's. The curved 16v ones for example wont be as good as the straight ones though
omp do a 4 point lower brace that looks good, it goes across the front wishbone bolts and to the front subframe. i dont have 1st hand experience with one though, but will be getting one sometime!
If you go for rubber top mounts then the mk3 vr6 setup is the best, but your getting some decent quaity coilovers so go for the ally top mounts. you will be surprised how good the ride comfort is!
if you can get it corner weighted, do it!
Offline Ian Carvell
« Reply #2 on: 24 January 2010, 17:18 »
Where abouts in the country are you Simon, I do that kind of work for most of the front runners in the Mk2 Golf GTI Championship so would be able to help you out.
My website is below...
Offline s1monc
« Reply #3 on: 27 January 2010, 18:43 »
Hi Ian, i'm near Canterbury Kent.
Offline Ian Carvell
« Reply #4 on: 14 February 2010, 16:36 »
Thats a bit of a trek then!!!
I am happy to do it if you are willing to travel....I have 3 Mk2 Golf Championship cars in this week for similar work.
Offline Stu.750
  • MMMMMMM Rust my favourite
« Reply #5 on: 14 February 2010, 17:15 »
Mr Carvall , have you done much work with French based stockhatchs ?
Offline Ian Carvell
Hi Stu,
I have indeed, we won the Stock Hatch Championship in 1998 and Runner-up in 1999 in a Peugeot 205.
Offline Stu.750
Brilliant
 to fair i reconised the Carvell name
your not a million miles from me so im sure ill be in touch in due course
