Author Topic: Idle woes  (Read 2407 times)
Offline maxp
  • J reg 8v digi gti
Idle woes
« on: 02 January 2010, 16:38 »
Its been a week of sorting out issues with the car (8v digi).
I previously had an issue where the car would idle fine, but then the revs would jump straight up to 1700rpm as soon as id touch the pedal (this is with the idle screw completely in).
So i bought a new pattern part ISV (pictured), thinking this may fix it. As soon as i fitted it, the car idled fine like the old part did, went for a 2 min drive, and noticed the revs getting stuck a little bit.
Anyway, parked up, unplugged the blue temp sender, revved x3 over 2500 rpm, plugged back in.
Now, although it idles fine, the engine revs to about 2800rpm as soon as i touch the pedal! With the blue temp sender unplugged, it sits at about 1300/1400 rpm.
Again this is with the idle screw all the way in.
Totally at a loss now, appreciate *any* advice.
Have since plugged the old ISV back in and it is back to square one (at least its vaguely driveable).
« Last Edit: 02 January 2010, 16:50 by maxp »
Offline RhosneigrGaz
  • More Doors Crew!
Re: Idle woes
« Reply #1 on: 02 January 2010, 16:47 »
Have u tried a new black temp sender?
'02 3dr Tornado Red Gti 20v Turbo
Offline maxp
  • J reg 8v digi gti
Re: Idle woes
« Reply #2 on: 02 January 2010, 16:49 »
I thought black sender was just for the dashboard display?
The blue was replaced less than a year ago, and i *think* it works, as the revs change when it's unplugged.
Offline Dan34
  • VTEC Powerzzzz
Re: Idle woes
« Reply #3 on: 02 January 2010, 17:07 »
Might be worth changing it just for peice of mind, only a tenner or so
  • More Doors Crew!
Re: Idle woes
« Reply #4 on: 02 January 2010, 17:21 »
I cahnged my black one as the dash gauge was knackered, idles better since!  :cool:
Offline Steve_B
Re: Idle woes
« Reply #5 on: 02 January 2010, 18:13 »
was the blue sensor from vw or pattern part?
Offline theclash
Re: Idle woes
« Reply #6 on: 02 January 2010, 22:16 »
mate i feel your pain.....i had exactly the same problem was considering selling the car it pi@@ed me off so much. i changed all vac pipes cleaned isv new blue sender cleaned throttle body cleaned and adjusted idle screw and although it would idle when up to temp it would always rev on its own  :angry: i was determend to sort it out and after further fiddling found out the throttle cable was ever so slightly adjusted to tight and wasnt letting it return to the stop and operate  the idle switch underneath the throttle body she now idles and behaves perfectly. check your cable and check throttle link returns fully on to the stop......worth a try
Offline Alec
Re: Idle woes
« Reply #7 on: 02 January 2010, 22:34 »
I'm sure I read a :smug: thread a few weeks ago with the exact same symptoms as this man, I'll try and find it.
Offline Sam
  • Sam I am
Re: Idle woes
« Reply #8 on: 03 January 2010, 00:55 »
Symptoms is a cartoon, i cant see the relevence
Offline Alec
Re: Idle woes
« Reply #9 on: 03 January 2010, 16:35 »
Dunno where that came from.... strange. I have been trying to sort my idle out today but all I have managed to do by changing the blue sensor is turn the exhaust into a bit of a flamethrower. Scared the living daylights out of me... I'm out of ideas now
