Author Topic: Fog Lights, Is this easy to do?  (Read 1649 times)
Offline MK4_20VT
« on: 17 October 2004, 21:20 »
I already have big bumpers on my motor, but I want to put fog lights into them & set them up to my fog switch.
How hard is this?
Can you simply put the 90spec wires into the 84 fog wiring?
Or is this going to be a pain  ???
free
Re: Fog Lights, Is this easy to do?
« Reply #1 on: 18 October 2004, 00:11 »
i put some on my old 16v. yes and no, it is but takes time, u gotta take bumper off to cut out the holes n mount them, i sepnt ?103, on 2 fogs, 2 mouting brackets, 2 bulbs, aload of wire , n a rely. frm GSF took most of a saturday to do 24hours later...............................yes i crashed it n they was boths smashed n bent :'( :'( :'( but never mind sh1t  happens,,,  u get older n wiser, I LEARNT A VALUBUL LESSION THAT DAY. DONT OVER TAKE WHEN THE CAR IN FROUNT OF THE CAR YOU ARE OVER TAKING IS TURNING RIGHT!
Veedubgt18v
« Reply #2 on: 18 October 2004, 00:39 »
isnt that obvious tho?
free
« Reply #3 on: 18 October 2004, 22:53 »
not when the pet station had been closd down 4 about a yeh!!!
Offline Dizzie
  • Make friends with your fast
« Reply #4 on: 18 October 2004, 22:57 »
shouldn't be too hard to wire up. you might have to run a new wire back to the switch unless you can find one from looking are the wiring diagrams.
free
« Reply #5 on: 19 October 2004, 02:07 »
that about is the hardest bit geting it to the dash, i used the same hole as my amp power cabel then took the air vents out to get better acsess to feed it up to the swich
Offline MK4_20VT
« Reply #6 on: 19 October 2004, 07:30 »
Thanx lads, weather permiting I will have a look this weekend.
I don't really have a prob with the fitting of the lights, just the wiring :-)
