Golf mk3
hardmonkeys
thermostat change
Topic: thermostat change (Read 1641 times)
daytona
GTI forum regular
thermostat change
31 December 2009, 13:41 »
do they have to make it so bloody hard to get at the thermostat housing off.u have to take off the alternater and power/st pump and belts just to change the bloody thing.
if in doubt,rev the arse out of it
roger1234
GTI forum regular
Re: thermostat change
31 December 2009, 14:02 »
Take the alternator housing off as well.
http://secondhandcars.forumup.co.uk
javalin
31 December 2009, 16:26 »
Be glad its not a Ford Fusion. Cut the aux belt off, Alternator off, O/S headlight out, jack the car up, change t-stat, re-assemble with new belt and using Fords belt tools...
A job for later in the year.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
roger1234
GTI forum regular
31 December 2009, 16:49 »
^^ Is that the zetec engine?
javalin
31 December 2009, 16:53 »
yeah the 1.4 16v
James
andc1
01 January 2010, 19:05 »
8 v i take it! yes mate fun aint they! make sure u put new seal on and tighten 2 bolts up enough!
AudiA8Quattro
Forum addict
Reply #6 on:
01 January 2010, 22:30 »
The audi a4 isn't much better.
rocketron
GTI forum regular
Reply #7 on:
01 January 2010, 22:43 »
balls i gotta do mine.......maybe.
96 golf GTI 16V
96 T4 1.9TDI
Its a dub thing.
christomk3gti
Reply #8 on:
02 January 2010, 18:44 »
I need mine doing aswell. dreading it.
Black 8v GTI............. Whats a Waffle Valve?
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Reply #9 on:
04 January 2010, 10:54 »
stop moaning, could be worse! could be trying to do it on a mk2 with PAS
its not that hard at all, 3 bolts to loosen so pas pump tension released, then remove 3 bolts and the entire pas pump and bracket assembly comes off. 2 bolts and stat out, refit reverse of removal. easy!
Golf mk3
hardmonkeys
thermostat change
