Author Topic: ABS light.  (Read 2119 times)
Offline Live in Hope
ABS light.
« on: 29 December 2009, 20:10 »
My ABS light has started coming on then going off? when it's on i have no ABS! is this a wheel sensor problem if so which one?
Offline VR6-Joe
Re: ABS light.
« Reply #1 on: 29 December 2009, 20:20 »
Sounds to me like an ABS pump problem.. but don't quote me on that
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline leegt5
Re: ABS light.
« Reply #2 on: 29 December 2009, 20:24 »
Try to get it on vagcom to see if one of your abs sensors are knackered !!
Offline MowatGTI
Re: ABS light.
« Reply #3 on: 30 December 2009, 11:04 »
My ABS light comes on sometimes too.
Only in really cold weather. Mostly when I've got the heater on, lights + wipers.
I think that its got something to do with low power coming out the battery.
Usually, if I increase the revs the light goes out.
Another thing I've noticed is that the headlights and fan do not run fully untill the engine is rev'd a bit too.
adamrob69
Re: ABS light.
« Reply #4 on: 30 December 2009, 12:33 »
it could be anything, most probably an intermittent problem with a sensor. You wont know for certain unless you get it on vagcom and it will tell you exactly then. Any decent vw garage will do this free of charge for you.
Offline AudiA8Quattro
Re: ABS light.
« Reply #5 on: 30 December 2009, 22:46 »
Where do you live then?
There aren't any decent garages round my way that will scan a car for free  :grin:
To the OP, if you haven't got access to VAG-com, unplug each sensor one at a time, test each one for resistance with a multimeter.
Make sure the ignition is off when you do this.
If any of the sensors read open circuit, then it is faulty.
The front sensor plugs are behind the front brake discs, the rear plugs are under the rear seat.
Hope that helps  :smiley:
Offline filthy
Re: ABS light.
« Reply #6 on: 31 December 2009, 10:07 »
Might just be a dirty sensor....
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
adamrob69
Re: ABS light.
« Reply #7 on: 31 December 2009, 10:25 »
SOLO VW in Burton. local(ish) vw specialist. they wont charge me for hooking up the car and reading error codes in my lunch time etc.
Offline leegt5
Re: ABS light.
« Reply #8 on: 31 December 2009, 12:21 »
If you can get over to Romford, Essex any time I'll put it on vagcom for you !!
VW BUSH
Re: ABS light.
« Reply #9 on: 31 December 2009, 19:06 »
