Author Topic: heater valves sorted with part no and price now  (Read 1822 times)
Offline billydude
« on: 16 October 2004, 17:23 »
a right good one this is
the heater works in the morning till it reaches normal temputure
then goes friggin freezeing
why ?? ???
I'm seriously confused
I've changed the water pump ran a hose through the matrix and its still the same? ???
my mini heater is better than this poxy golf one? ;)
« Last Edit: 19 October 2004, 14:54 by billydude »
Offline billydude
Re: heater troubles mk2 16valve
« Reply #1 on: 16 October 2004, 18:54 »
I see this is quite a common problem after searching for heater on here
and all threads lead to those stupid valve things
but my pipes are hot either side of the stupid valve things? ???
come on chap's don't tell me the only way to make this golf warm involves petrol and a match? :D
Oh and I swapped those stupid valve things from our old golf which had a decent heater and it made no differnce  ???
Blue MK2
« Reply #2 on: 16 October 2004, 23:48 »
get rid of the valves and then give it a go?
Offline billydude
« Reply #3 on: 17 October 2004, 01:56 »
I'll have to try and find some pipe in that odd size and give it ago
Offline billydude
« Reply #4 on: 17 October 2004, 12:50 »
well after cutting up 2 of the steel water pipes to get a peice of pipe to replave those stupid valves
it finaly has a heater  :o
although I'm confused by those valves since one pair worked till fitted to this poxy valver  ???
but atleast I never had to resort to this to get warm
 :D  :D
Offline billydude
« Reply #5 on: 19 October 2004, 13:29 »
heres the cure  ;)
?30.53 from vw dealers
