Author Topic: What have I broken then...  (Read 1190 times)
Offline Winso
« on: 29 December 2009, 09:26 »
Had a fight with a kerb this morning (fecking ice). Only hit it at about 5-10mph but managed to seriously break something. Off side front wheel is now sitting in the back of the arch and rubbing on the lining. Don't think my mechanic is working at the moment so it's going to be sitting in the work car park for a while! Any ideas on what I've broken?
Offline roger1234
Re: What have I broken then...
« Reply #1 on: 29 December 2009, 09:40 »
Jack it up and remove the wheel, it should be obvious what youv'e damaged.
Offline Winso
« Reply #2 on: 29 December 2009, 10:08 »
Wish it was that easy...
Got no trolley jack and the widowmaker definately won't fit under.
Offline VR6-Joe
« Reply #3 on: 29 December 2009, 12:35 »
Hmm sounds like you've bent the track rod
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline Cable
« Reply #4 on: 29 December 2009, 13:06 »
sounds like you have bent your lower suspension arm...
Offline Winso
« Reply #5 on: 29 December 2009, 14:33 »
Bent wishbone and destroyed ball joint. Oh, and a 'slightly' kerbed TT comp. I've kept the bit of kerb as a momento though!!
« Reply #6 on: 29 December 2009, 15:56 »
Have a good look around where the wiishbone bolts, if you have hit it hard enough to bend it then you may have tweaked the shell.
