Blocked jet? No water in the bottle under the bonnet? Do the front ones work?
The jet will be blocked, very common problem.
Quote from: AudiA8Quattro on 28 December 2009, 21:36The jet will be blocked, very common problem.Is there an easy way of unblocking it?
Quote from: robertb2700 on 28 December 2009, 21:53Quote from: AudiA8Quattro on 28 December 2009, 21:36The jet will be blocked, very common problem.Is there an easy way of unblocking it?Garage airline but pop the cover off inside the tailgate and blow it through that way.
Quote from: Wayne on 28 December 2009, 21:55Quote from: robertb2700 on 28 December 2009, 21:53Quote from: AudiA8Quattro on 28 December 2009, 21:36The jet will be blocked, very common problem.Is there an easy way of unblocking it?Garage airline but pop the cover off inside the tailgate and blow it through that way.ok sounds simple enough i think
Quote from: robertb2700 on 28 December 2009, 22:03Quote from: Wayne on 28 December 2009, 21:55Quote from: robertb2700 on 28 December 2009, 21:53Quote from: AudiA8Quattro on 28 December 2009, 21:36The jet will be blocked, very common problem.Is there an easy way of unblocking it?Garage airline but pop the cover off inside the tailgate and blow it through that way.ok sounds simple enough i think Yes easy, open the tailgate and remove the inner cover, clips on and one small screw you then see the motor and washer piping, remove and blow through.
Quote from: Wayne on 28 December 2009, 22:37Quote from: robertb2700 on 28 December 2009, 22:03Quote from: Wayne on 28 December 2009, 21:55Quote from: robertb2700 on 28 December 2009, 21:53Quote from: AudiA8Quattro on 28 December 2009, 21:36The jet will be blocked, very common problem.Is there an easy way of unblocking it?Garage airline but pop the cover off inside the tailgate and blow it through that way.ok sounds simple enough i think Yes easy, open the tailgate and remove the inner cover, clips on and one small screw you then see the motor and washer piping, remove and blow through.Thanks is the machine for putting air in powerful enough?
