just had i plugged in and it said the n75 valve was shot.. so i put a new one on and its still the same?? does anyone no if ya can here the turbo working usually?? as mine is very faint or is there a way i can up the boost cheers
[/quote]
you shouldnt be able to hear the turbo unless you have a BOOST LEAK
best thing to do mate is get it on the rollers and see how much boost its running etc. R-TECH only charge £35 i think? i took mine to R-TECH for mapping and when they put it on the rollers in standard trim it was 150.6 hp and boosting 8psi just how it should. mine is a s reg (10 years old
your problem may be nothing but baring in mind there is more than one n75 code on vag com.
Have you had a look around the turbo intake pipe (TIP)?
have a look around the electronic boost controller (n75) make sure all wires are in tact and connections ect.
if all else fails eitherr 1) get some advice of some knowledgeable guys of ere
2) plug it back in to vag com or 2) get it to a rolling road.
hope you get it all sorted mate.
lee
