Author Topic: im back- with a problem!  (Read 1536 times)
Offline sean26
« on: 28 December 2009, 17:09 »
i sold my mk3 gti and bought a 1.6 mk1 cab. a few days after owning it, i couldnt start it from warm. it went down hill untill it wouldnt run at all. so a trip to the garage and turned out the carb was shot! (pierburg2e2) so i got another for next to nothing and in good working order. so i swopped them over and replaced all the vacuum pipes and all good! until it gets warm. now it will stall when hot unless i have a bit of throttle. any ideas as the choke works fine, and the carb as it should. its just when it gets hot and the thermostat opens it dies!!
Re: im back- with a problem!
« Reply #1 on: 29 December 2009, 10:27 »
have a read of the 2e2 faq, hopefully that'll give you an idea :)
http://www.golfgtiforum.co.uk/index.php?topic=18871.0
« Last Edit: 29 December 2009, 10:29 by rubjonny »
Offline MK1 Ali!!
« Reply #2 on: 18 January 2010, 19:58 »
u could also have evaporation, check fuel lines are not getting too hot!!
