Author Topic: mk3 coilover....is this knackered :(!!!  (Read 4260 times)
Offline mac7
Re: mk3 coilover....is this knackered :(!!!
« Reply #30 on: 28 December 2009, 17:14 »
Wayne's using his brain :wink: I think...
The upper spring platform is supposed to be secured to the damper piston rod, otherwise the thing wouldn't work, would it?
« Last Edit: 28 December 2009, 17:40 by mac7 »
Golf R
« Reply #31 on: 28 December 2009, 21:53 »
Your thinking the same as me, something has let go.
Offline vdubnut
« Reply #32 on: 28 December 2009, 21:57 »
 :sad: not good news :( im heading to have a proper look tommorrow so keeping everything crossed.....it did seem odd i could push the rod back into the shock manually....
Offline vdubnut
« Reply #33 on: 29 December 2009, 16:47 »
update :)....took off the coilover and it looked fine.....looked again..... the top spring plate that should hold the damper...had a bigger hole than is should hence the rod going through it....(installed wrong i think :o not by me tho think they missed out a washer!)  steel washed added where it should have been and its fine again! need to check the other side tho
Huge thanks to everyone who input into helping your time is appriciated !Have an ace new year guys! :smiley:
Offline Khare
  • The bear that khares
« Reply #34 on: 29 December 2009, 16:58 »
That's why I argued that it couldn't be the top mounts, I knew something else had to be wrong. Until you look thought you can't really do much more than suggest ideas. Good luck with the repair.
Offline JC
  • Back in the North.
« Reply #35 on: 29 December 2009, 17:08 »
good guess Khare  :grin: :kiss: :tongue:
Offline Khare
« Reply #36 on: 29 December 2009, 17:09 »
Ye ye  :kiss:
