update..in case it helps...car is sitting at normal height...
Quote from: vdubnut on 28 December 2009, 12:16update..in case it helps...car is sitting at normal height...Well that just adds to confusion. If the ride height is the same then it looks like it's not a spring issue, although still check them. Your best bet is to remove the whole coilover and check it properly. It could be the top of the damper has broken off or something similar.
