Author Topic: Does this sound like a fuse?  (Read 1239 times)
Offline Dmonday
« on: 27 December 2009, 16:33 »
hi guys,
well after a day freezing in the garage today i ran across a problem, when i dont have my keys in the ignition i dont see my milage of the car, only when i have the key in position 2 & 3
also my interior light no longer works! as im not too great with electrics could this be a fuse / all linked to the same thing?  :shocked:
cheers, Dan
Offline roger1234
Re: Does this sound like a fuse?
« Reply #1 on: 27 December 2009, 16:39 »
Must be unrelated if your trip is working with ign thats ok. If the int light is not working with the switch or the doors then most likely bulb or fuse.
Offline Dmonday
« Reply #2 on: 27 December 2009, 18:28 »
they both went at the same time  :undecided:
my push start button no longer works either, and when i put the key to position 2 its asif the battery had ran out e.g. sets the clocks back to 0:00
thanks for the help, dan
Offline Alec
« Reply #3 on: 27 December 2009, 18:36 »
Sounds like a MK3  :evil:
Offline opel
« Reply #4 on: 27 December 2009, 18:38 »
my clock always use to set back to 0.00 it was the battery that was nackered replaced that ad it whizz away lovely
Offline hyland770
  • Vw Golf 1.6 estimated to have around 500+ bhp
« Reply #5 on: 27 December 2009, 21:55 »
How long after fitting the push button start did it start happening!? Im gettin the same one as you and dont want my electrics to go down the pan!
Offline Dmonday
« Reply #6 on: 28 December 2009, 15:02 »
just off to buy a new fuse now, ill give you a heads up when i get back see if it works!
Update: okay that seemed to fix all my problems, just the blown fuse  :laugh:
« Last Edit: 28 December 2009, 17:18 by Dmonday »
Offline hyland770
« Reply #7 on: 28 December 2009, 19:42 »
Pheeeeew!!!
Offline justalex81
« Reply #8 on: 28 December 2009, 19:51 »
got to ask yourself why it blew and will it do it again???
Offline Dmonday
« Reply #9 on: 28 December 2009, 21:41 »
a bare wire was touching the metal in the dash  :lipsrsealed:
replaced that also and it all seems to be working okay!
