Author Topic: clean inside of headlights  (Read 909 times)
Offline robertb2700
« on: 27 December 2009, 11:55 »
as the title really  :smiley: looking to clean the inside of my headlights as one looks a bit grubby after sitting in a garage for 6months while the vento front was on. are they easy to seperate once they're off the car? if so how do i go about this? any help would be great  :cool:
Rogue trader - pm's disabled - robertb2700@live.co.uk
Offline boneybradley
  • Back in a Mk3...
Re: clean inside of headlights
« Reply #1 on: 27 December 2009, 15:53 »
remove the metal clips and stick the lights in the oven for a few minutes to soften the sealant (use common sense and don't have the oven at 1000degrees) and they should pull apart (use a sharp knife to remove/cut the sealant) and they should separate easy enough!
ensure you clean all the old sealant off and ensure you reseal them properly of they will mist/discolour quickly
Offline robertb2700
« Reply #2 on: 27 December 2009, 16:52 »
thanks, will give this a wee bash during the week  :smiley:
