Author Topic: Vagcom  (Read 1603 times)
Offline Primus84
Vagcom
« on: 26 December 2009, 19:21 »
I'm interested in buying a vagcom lead off ebay but I'm not sure which type I need, could anyone link to the correct type for a MkV GTI please?
Cheers!
Offline topher
  • Administrator
  • fully functioning
Re: Vagcom
« Reply #1 on: 26 December 2009, 20:32 »
I'm not sure any of the ebay ones are suitable for the MK5 as they need to be CAN based. You can get a cloned K+CAN vag commander but its not the same thing. It'll read fault codes but its more for communicating with/flashing the instrument cluster eprom. It won't do any of the adaptions, coding, logging or other fun stuff that vagcom (now known as VCDS) can do.
Offline Hurdy
Re: Vagcom
« Reply #2 on: 26 December 2009, 23:29 »
Stick with Ross-Tech cables - they are the best and if you buy from them you get lifetime software support :cool:
For the MKV you can have the more compact and slightly cheaper MICRO-CAN lead.
http://www.ross-tech.com/vag-com/Micro-CAN.html
 :smiley:
Seat Leon Cupra Black 290 DSG
Offline Primus84
Re: Vagcom
« Reply #3 on: 27 December 2009, 10:47 »
I only want one to be able to read faults etc and the Ross tech ones are far too expensive. I was hoping for an eBay bargain one. Do none of these work with the MkV?
Offline mortygt140
Re: Vagcom
« Reply #4 on: 27 December 2009, 11:08 »
out of experience I tried the ebay option and ended up sending it back cos it just kept breaking,  ended up with the genuine Microcan.
I also have Vag+k-Can Commander cos I do a few mk5 cluster swaps but this can kill your car if your not careful!! press the wrong but and you'll wipe the module coding completely.
Darren
Offline Ed30DSG
  • Edition 30 - gone - Audi S3 here
Re: Vagcom
« Reply #5 on: 27 December 2009, 12:15 »
If you only need to read/clear fault codes then one of these will do ... http://cgi.ebay.co.uk/U281-VW-Audi-CAN-BUS-Scanner-Code-Reader-OBD2-Seat-EOBD_W0QQitemZ370309374917QQcmdZViewItemQQptZUK_Diagnostic_Tools_Equipment?hash=item563828a3c5
They do work on the later can-bus cars.
