Author Topic: 1997 GOlf MK3 TDI Key Replacement  (Read 4168 times)
Offline gunnag
« on: 23 December 2009, 09:56 »
Ive only got one key for my 1997 MK3 TDI and am thinking about getting a spare.
IM not sure whether there is a transponder in the key and if an immobliser is fitted, I cant see anything obvious. There was an after market alarm fitted years ago but this had been partly removed. I guess this points to there being no immobliser.
Can I simply take the key to a locksmith and have a copy made or do I need to go to my VW stealer?
All info welcome! :smiley:
Re: 1997 GOlf MK3 TDI Key Replacement
« Reply #1 on: 23 December 2009, 10:07 »
Pop the key open and see if you have a chip inside.
Offline justalex81
« Reply #2 on: 23 December 2009, 13:45 »
vw stealer will lift £120 notes from your wallet for a new key!!!
Offline gunnag
« Reply #3 on: 23 December 2009, 14:04 »
Ive opened up the key and there is a small black rectangular box on the edge, is this the transponder? I cant see any chip or wires.
Offline justalex81
« Reply #4 on: 23 December 2009, 14:52 »
that is indeed the transponder. take it out then start your motor. let it run for at least 30 seconds. if it does that then you don't need a transponder key just a normal one which will cost peanuts. if it doesn't start or starts but cuts out then you need a transponder key which you can only get from vw (legitimately)  :wink: :wink:
Offline robby
« Reply #5 on: 23 December 2009, 21:58 »
Wasn't an old trick to take the transponder out of the key and fix it in the steering cowling next to the ignition lock - the ign can then read the transponder so you can get a cheap replacement key
« Reply #6 on: 24 December 2009, 00:20 »
Yes you can do it that way but the insurance companys can refuse to pay out.
Offline gunnag
« Reply #7 on: 24 December 2009, 15:14 »
I took out the transponder and tried starting the engine, it ran for a couple of seconds before cutting out.
Looks like I have a transponder key, anyone know where I can get a spare one cut?
Offline justalex81
« Reply #8 on: 24 December 2009, 15:22 »
yep VW!!! like i said they want £120 + vat last time i checked
Offline boneybradley
  • Back in a Mk3...
« Reply #9 on: 24 December 2009, 16:04 »
most decent key cutters (stimpsons etc) can do them for £20ish coded.....
