Author Topic: push button start  (Read 9432 times)
Re: push button start
« Reply #30 on: 23 December 2009, 12:36 »
Unfortunately I don't have any fitting advice as mine was already on my golf when I bought it.
But I will say I love this mod, when people jump in my golf and I say press that button there for me (all casual), then they do and they're all like "woooow".
Mine's a crome button with a crome surround, and whoever fitted it must've done it properly because the button won't work whilst the engine is running, and you can't start the engine via the ignition.
I love it.... Thumbs up for meĀ  :grin: :cool:
It should not anyway as that will burn the starter out, also what happens if the button fails.
Offline hyland770
  • Vw Golf 1.6 estimated to have around 500+ bhp
« Reply #31 on: 23 December 2009, 22:38 »
hmmm im going to run mine in a parallel circuit so the ignition will still work the usual way, pointless but cool i think, the kit shoudl get here tommorrow or next week sometime and ill do a write up so people can do it too if they so please!
Offline Matty-MK3
  • Automatic boats FTW.
« Reply #32 on: 23 December 2009, 23:08 »
Fair point.
They irritate the sh!te out of me personally, but fair play.
Fit an OEMish looking one, the big red button ones only just about work in Civics.
Golf MK3 1.8 auto and I didn't pay a grand for the "priveledge" :grin:, auto windows all round and a AC. Oh and I've got a luggage net you pricks!
Does that make my willy look bigger?
Oh yeah it's called Helda or something....
Offline bored_Welsh_lad
« Reply #33 on: 23 December 2009, 23:32 »
i believe it has to be declared ....
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline chris231280
« Reply #34 on: 24 December 2009, 10:51 »
I love it.... Thumbs up for me  :grin: :cool:
I do believe i will be screwed........... And not in the good way hahaha..!!
I would hope that, with the key in the ignition, and the ignition still on, i would be able to pull the button back out of the dash and cross the wires to power the starter motor.
Or the car will blow up and the problem will be irrelivant  :undecided:
Offline Khare
  • The bear that khares
« Reply #35 on: 24 December 2009, 11:11 »
Then when you wire it up make sure you do so so that you can still turn the car on via the key.
Offline FOREST GREEN
« Reply #36 on: 24 December 2009, 14:29 »
I've got 2 cars, I think I might put a push button in my mk3 to then try & start my mk1 :grin: Now that, you have to admit WOULD be impressive!!!!!!!!
 :tongue: :grin: :tongue: :grin: :tongue: :grin: :tongue:
Offline hyland770
« Reply #37 on: 24 December 2009, 20:21 »
Like i said ill do a guide on so its easier for you when ive done mine, parts should get here day after boxing day! :)
Offline chris231280
« Reply #38 on: 27 December 2009, 10:42 »
That would be impressive  :grin:......... or you press your mk3 button, and start your neighbours car..!!
Offline Dmonday
« Reply #39 on: 27 December 2009, 16:30 »
i used the button off ebay  :smiley:
just hooks up to the two thick wires (red/black & red) coming from the ignition and it gets power from (red/white & green/blue) from the cigarette lighter.
works fine and i like it  :wink:
