Author Topic: gti 8v safe mode prob  (Read 1418 times)
Offline JIM1880
« on: 22 December 2009, 13:09 »
hey i have a mk3 gti 8v and its stuck in safe mode. have checked the timing and thats spot on. have searched on here and still no joy, checked everything. is there anything that i have missed or any sensor that could be at fault? thanks jim
Offline roger1234
Re: gti 8v safe mode prob
« Reply #1 on: 22 December 2009, 13:26 »
Have you tried disconnecting the battery for half an hour or so to reset the ecu. Cam timing is the usual culprit have you done your belt or anything?
« Reply #2 on: 22 December 2009, 13:32 »
Welcome to the site, as above you could try disconnecting the battery also well worth checking the cam timing.
Offline JIM1880
« Reply #3 on: 22 December 2009, 14:17 »
have tried disconecting the battery and checked cam timing and everything seems fine just wont rev over 5000 rpm. anymore ideas please
« Reply #4 on: 22 December 2009, 15:30 »
If it will not rev over 5000rpm then I would suggest cam timing.
Offline boneybradley
  • Back in a Mk3...
« Reply #5 on: 22 December 2009, 19:31 »
vag-com and clear the codes if you haven't already and rescan after driving and see if any come back
Offline javalin
« Reply #6 on: 22 December 2009, 19:52 »
ignition timing.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline mark-mk3gti
« Reply #7 on: 23 December 2009, 06:26 »
i had this when i first got my gti, have you got vag-com?  if so have a look at what numbers your hall sensor is showing..  when you start the car they normally change (hopefully into spec) mine werent changing no matter what so i put a new dizzy on and hey presto.. turned out the hal sensor was knackered,  so i checked cambelt timing and was ok (thanks to the guys on here for showing me how) and all is good.
Offline bored_Welsh_lad
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
