Author Topic: Subframe and engine mounts replacement  (Read 1175 times)
Offline jester9766
« on: 22 December 2009, 11:31 »
 :sick:
Hi All, In addition to requiring a replacement Carb to swop the useless Pierburg I need to sort out my subframe and engine mounts as they have rusted pretty badly. Surface rust so far but I want these resolved as the car had been standing a while and the rust set in. The rest of the Golf CL is mint and I would like to continue its care by doing these jobs. Anybody out there with resolves or ideas? If you can do the job get in touch!! Cheers!!
Offline Diamond Hell
  • Opinions я Us
Re: Subframe and engine mounts replacement
« Reply #1 on: 23 December 2009, 15:50 »
Mounts you can replace, subframe you can probably get a replacement for, but it might be easier if yours is still good to get it shotblasted and powdercoated.
Offline th3_f15t
« Reply #2 on: 28 December 2009, 12:27 »
Is surface rust on a subframe really worth worring about? I would of thought that's it's a pretty solid bit of kit and that surface rust is all the corrosion it'll suffer. Then again I'm no mechanic, body work specialist... basically I'm a monkey with a spanner.
Moving over to Flickr, sorry for the broken picture links!
  • Opinions я Us
« Reply #3 on: 29 December 2009, 13:48 »
Given the age of Golf2s there's plenty of opportunity for a subframe to have rusted out by now.
If it's surface rust though, meh.
