Author Topic: Heaters not working  (Read 1001 times)
Offline lambogolf
Heaters not working
« on: 21 December 2009, 11:40 »
Morning All...
Hopefully someone can help..
Was driving around last night and the heating started to smell bad.. like a burining smell.. thought nothing of it.
About an hour later it cut out.. thought it was strange.. i went around a tight roundabout.. then it kicked back in for a while..
Now it has cut out again and will not work at all.. i have check all fuses nothing... I have took off all the covers and everything is still plugged in and attached.
Anybody got any ideas as its really cold!!!
Cheers  :smiley:
Offline axewielder
  • 95 dragon 8v
Re: Heaters not working
« Reply #1 on: 21 December 2009, 11:47 »
could be the resistor pack thing packing up, otherwise double check all connections+ put some copper grease on them
Offline lambogolf
« Reply #2 on: 21 December 2009, 11:50 »
Where is the resistor pack?
This car so far has been nothing but problems..
I got a bad water leak as well lol.. that is coming from the water pump though.. Also have an oil leak  :sad:
Slowly i am getting there though  :smiley:
Offline VR6_Wherry
« Reply #3 on: 21 December 2009, 11:51 »
Try unplugging it from behind the switches and then follow the wires to see if any have split or even fried. i hope thats good advice?? haha im sure i'll be told other wise!  :grin:
Offline lambogolf
« Reply #4 on: 21 December 2009, 11:54 »
i will go have a look now as im on lunch :)
Could it be a relay or anything.. and that would be why it is burning?
Offline lambogolf
« Reply #5 on: 21 December 2009, 12:17 »
Just had a check.. there is a single red wire going into small box with a group above them.. the Red wire is getting really hot and starting to melt..
Anyideas what cause of this could be?
Cheers  :smiley:
