Author Topic: New rear shocks noise  (Read 1507 times)
Offline admc6
« on: 21 December 2009, 11:30 »
I've had both rear shocks replaced with new standard ones...
Am i right to expect these to make some setting in noises..creaks etc?
Re: New rear shocks noise
« Reply #1 on: 21 December 2009, 11:41 »
Would guess so unless the rear top mounts are knackered.
Offline admc6
« Reply #2 on: 21 December 2009, 12:12 »
nar top mounts are alright as far as i know
Offline daytona
« Reply #3 on: 21 December 2009, 16:08 »
new shocks at the back are prob just showing up rear axle bushes need replacing.does it creak when getting in and out.
if in doubt,rev the arse out of it
Offline admc6
« Reply #4 on: 21 December 2009, 23:30 »
only creaks when shock is pushed in the most. the axle bushes have been changes this year already
« Reply #5 on: 21 December 2009, 23:48 »
Are the springs ok
Offline admc6
« Reply #6 on: 22 December 2009, 10:03 »
I was told they where...and they didnt make a noise before they where changed
Offline BlazinGTI
« Reply #7 on: 22 December 2009, 15:44 »
just had my rear shocks replaced and no creaking noise!!!
not that is any help to you!
Offline *tell*
« Reply #8 on: 22 December 2009, 18:38 »
when i fitted new shocks i was told by a friend in the trade.
to make sure you tight the bolt when the wheels are on the floor
then tight the bottom bolts up (near the brakes)  :undecided:
Offline boneybradley
  • Back in a Mk3...
« Reply #9 on: 22 December 2009, 19:34 »
what make of shockers are they?
