Author Topic: MFSW question!  (Read 2166 times)
Offline HasH
MFSW question!
« on: 20 December 2009, 16:41 »
hello, i have just won a mfsw on ebay from cocopops, a member on here. i have just been having a read up and it turns out i have the wrong control module, i have 1K0 953 549 AF which isnt compatible! and i also read that the only functions available for the stereo are volume and mute if you only have a mid-line display, which i do!
well its a good job i only wanted the steering wheel for the look and shape of it, not for the functions lol.
anyway, my question, seeing as im not bothered about the controls, would it be possible for me to pop out the buttons on the mfsw and put in the blank caps from my original wheel? and would i need the new airbag harness or would i simply be able to connect the airbag as i would in the original wheel being as i wont have the buttons in it?
Offline CocoPops
Re: MFSW question!
« Reply #1 on: 20 December 2009, 18:41 »
The plastic caps "should" pop off yours, don't quote me on that tho!  :grin:
the harness is only needed if you use the buttons.
Basically, the cable from the airbag plugs into the central boss and the mfsw buttons plug into the middle of those two, so hence harness needed.
2018 GTI Performance Pack DSG 5dr, Tornado Red, Leather, 18" Seville Wheels, DCC Suspension, Tints, RVC
2018 Lotus Elise Sport220
Previous : 1983 Mk1 Golf 1.1 & 2008 Mk5 Golf GTI Ed30
Offline HasH
Re: MFSW question!
« Reply #2 on: 20 December 2009, 18:43 »
all is good then! thanks for the info coco!  :wink:
Offline TagnuT
  • Edition 30
Re: MFSW question!
« Reply #3 on: 21 December 2009, 09:05 »
HasH you have PM.. :smiley:
Bye Bye Edition 30
Offline FamilyDub
Re: MFSW question!
« Reply #4 on: 21 December 2009, 09:14 »
I wanted that wheel...  :cry:
MKV GTI | Reflex Silver | 5-dr | Anthracite 17" | Manual | Highline MFD | Cruise | Revision 'D' DV | Dirty Pipes |
The GTD is like a blow up doll. The GTI is like a proper woman. Sure the doll might last longer, and the woman might have higher running costs, but which would you rather have?
Offline Sootchucker
Re: MFSW question!
« Reply #5 on: 21 December 2009, 11:02 »
Yeah, the buttons are held in by a little screw that's visable when the air bag is removed. Take the screw out and the switch assembly can be withdrawn and the blank version replaced and then re-atached with the same screw.
Five minute job.
Offline HasH
Re: MFSW question!
« Reply #6 on: 21 December 2009, 11:04 »
Five minute job.
thanks for confirming Norbreck21a!
Offline HasH
Re: MFSW question!
« Reply #7 on: 24 December 2009, 15:03 »
hello again, i fitted the wheel this morning, and just for future reference for everyone...the blanks from a standard wheel WILL NOT fit a steering wheel with buttons. so it looks like im going to have too buy the new control unit, i cant have buttons that dont do anything  :cool:
