Author Topic: Heater control Bulb replace.  (Read 26136 times)
Offline old_n07
« on: 19 December 2009, 16:11 »
On vehicles with the manual air conditioning controls there is one small bulb that illuminates all three dials. The bulb is located behind the centre control knob.
The bulb no. is 286 and its 12v 1.2w, £1.99 from halfords or 45p with a trade card
Turn the knob to the upright position and pull it to remove the centre knob, cover the pliers with some cloth to protect the switch
Bulb Location arrowed
Remove the bulb using either a pair of needle nose pliers with something like a rubber band round the ends to provide grip on the bulb or a thin piece of tubing pushed over the bulb.
Put in a new bulb
taken from the guide I did over on the dark side
Neil
« Last Edit: 29 December 2009, 18:42 by Rhyso »
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
Offline gijoebloggs
  • Mk4 GT Red I
Re: Heater control Bulb replace.
« Reply #1 on: 27 October 2010, 13:21 »
Hi Mate, Cheers for the post, mine went a long time ago and thought I would have to remove all sorts to get to it. Will get it done this weekend J
Offline daveski
« Reply #2 on: 30 December 2010, 21:06 »
Thanks for this post. Going to check mine and replace it tomorrow :)
Offline ABOO
« Reply #3 on: 31 December 2010, 18:52 »
No dis-respect to guide above mate, but get yourself a carton of Ribena and look at the job in hand. When drunk it, use straw to push on and remove then replace bulb.
That's today's top-tip... :wink:
2001 aum 1.8T
Offline daveski
« Reply #4 on: 31 December 2010, 20:45 »
I'm confused by that tip but guess it will make sense when I come to change the bulb
Offline ABOO
« Reply #5 on: 01 January 2011, 18:50 »
Believe me my good man, all will deffo become clear... :smug:
2001 aum 1.8T
Offline daveski
« Reply #6 on: 02 January 2011, 18:51 »
Got the bulb out earlier, completely forgot about the straw tip! Certainly see what you mean though :)
Offline daveski
« Reply #7 on: 03 January 2011, 19:47 »
Ok I replaced the bulb but after a few mins it went off again. Is there anything else that could be wrong?
Offline ABOO
« Reply #8 on: 04 January 2011, 08:35 »
Is it deffo pushed right into holder daveski??? Has it gone off completely or just dimmer, as replacement bulb isn't as bright as original..
2001 aum 1.8T
Offline daveski
« Reply #9 on: 04 January 2011, 10:59 »
Its gone off completely. I'll have another go at pushing it into the holder later, hopefully that will fix it as I was just getting used to seeing the heater controls illuminated!
