Author Topic: on motorway no pwer at all  (Read 31976 times)
Offline vw-8v
Re: on motorway no pwer at all
« Reply #20 on: 27 December 2009, 15:12 »
bought allard kit so it on its way with the fault reader. cheers
Offline Adam
« Reply #21 on: 27 December 2009, 15:22 »
keep us posted
Down Hill From Here.
Offline vw-8v
« Reply #22 on: 04 January 2010, 22:05 »
fault reader has turned up but still no allard kit, will update once got kit.
one q though where does the reader attatch to the engine? ecu?
Offline topher
  • Administrator
  • fully functioning
« Reply #23 on: 04 January 2010, 22:14 »
here
the trim piece covering it just pops off (pull it from underneath)
Offline asif
« Reply #24 on: 07 January 2010, 12:24 »
Fault reader? Is that Vagcom your talking aboutor something different?
MK7 GT Bluemotion Tech TDi 150
Offline Adam
« Reply #25 on: 07 January 2010, 12:27 »
Vag-Com is a program for MS Windows to use with a OBD2 cable. The Fault reader is a standalone device, looks like this -
Offline asif
« Reply #26 on: 07 January 2010, 12:29 »
Pro's con's on this device?
Worth having instead of vagcom?
Offline Adam
« Reply #27 on: 07 January 2010, 12:34 »
Vagcom the Licensed version costs ££, VAG-com can do alot more than a simple fault code reader. All the fault code reader can do is what it says, read fault codes and clear them. The fault code reader only gives you a code and you need to find out what the code is.
Offline asif
« Reply #28 on: 07 January 2010, 12:44 »
Cheers for that info Adam
Offline topher
  • Administrator
  • fully functioning
« Reply #29 on: 07 January 2010, 15:49 »
Not completely true.. i have some MS509 scanners in stock that also do live data logging/recording and has built in DTC identification
not as flexible as vagcom but you can use them on pretty much any car
