Author Topic: stalling getting worse,crank sensor/immobiliser?  (Read 11078 times)
Offline 95gti8v
« on: 18 December 2009, 15:58 »
I've been having usual problem recently, oil light flash, rev's drop dies.
I replaced fuel relay 167 and ECU/hall relay30 which made no dirfference.
Basically after driving the car for a while (maybe 10mins...don't know if maybe when engine reaches certain temp) it just stalls and does it irratically after that.
Today it stalled 6times in the last mile of my drive home, twice at traffic lights and took an age to start again each time (although started straight away first time). It's now become unbearable to drive!!!!!!
I just noticed that i have been using the spare VW key i got with the car and not the key with the button the previous owner had been using (button seems defunct but haven't check battery in it yet). Could this be having any bearing on immobiliser (I'm assuming a 95 GTi has one fitted as standard??)
I'm clutching at straws here I know, but have ordered a new crank sensor which is my next port of call to try and sort the beast  :cry:
many thanks in advance guys
Offline javalin
Re: stalling getting worse,crank sensor/immobiliser?
« Reply #1 on: 23 December 2009, 21:30 »
Could be coolant temp sensor again.  Controls the fueling as the engine warms up.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 23 December 2009, 21:50 »
have you replaced the power relay? or is that the ecu relay? the way youl find out more is by reving the car while at idle rev it quite a bit and if the car cuts out then its the power relay. i dont know if the ecu and power relay is dif, i had the same prob took it to a specialist and he checked it with vag-com and he said that the ecu wasnt getting power and said 2things 1 ecu might need replacing or its the "power" relay. and then replaced it with a dif colour and since then its been fine touch wood.
hope that helps mate.
p.s have you checked it with vag-com?
Shark  :wink:
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline 95gti8v
« Reply #3 on: 24 December 2009, 17:32 »
replaced the crank sensor on Tuesday and fingers crossed it's been ticketyboo since!
The old one had a worn bit in wire where goes round back oil filter probably not helping!
Hopefully i can now enjoy it a bit more, have the metal coolant pipe to replace and few other wee fiddly jobs to do  :smiley:
Offline javalin
« Reply #4 on: 24 December 2009, 19:31 »
oh yes I know the coolant pipe you mean! - done it on my GL and will be doing it on the GTI next year!
Good stuff.
Offline 95gti8v
« Reply #5 on: 26 December 2009, 10:43 »
Is there anything special you need to do when replacoing it or just rip it out and throw the new one in along with antifreeze?
Offline javalin
« Reply #6 on: 26 December 2009, 11:36 »
yup - just drain the system, replace and refil.
James
Offline 95gti8v
« Reply #7 on: 26 December 2009, 12:17 »
Happy days  :smiley:
Offline cuzza
« Reply #8 on: 05 January 2010, 12:41 »
Hi, my car has done this a couple of times and checking the sensor the case seems to be cracked so I have ordered one from here;
http://cgi.ebay.co.uk/NEW-Crankshaft-position-Sensor-fits-SEAT-IBIZA-Toledo_W0QQitemZ370198703655QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item56318fee27
Anyone used them? seems to be the same part number and hopefully should fit my 98 R 8v without issue?
Offline Rushtoni1985
I had this too! :o
« Reply #9 on: 07 January 2010, 03:43 »
I've had this exact same problem for ages!  :cry:
I probably have the same problem still to be honest but I lost faith in driving my car far distances so it doesnt get the chance lol.
Im now having another problem- as soon as i start driving my car I hear a rattling from underneath the centre of the car, when this happens I seem to lose power but intermitently and my rev counter suggests that the engine is running smooth.
Is this probably related to the problem I (and you) was having before? And if not does anyone have any advice on what it might be?
I love my golf but driving it is becoming increasing nerve-racking lol. Save me!
Thank you all :)
