Ok, so a quick scan has thrown up the following...
17704 - Cooling system malfunction (which I would guess is the thermostat that needs changing)
17705 - Connection turbocharger - throttle valve pressure hose (is this as obvious as it sounds? Where is this hose located? would this explain my massive drop in power?)
17947 - Clutch Vacuum Vent Valve Switch Incorrect signal (this one i have no idea! HELP!)
Anyhow, the power only dropped last night, and i've only just scanned for codes. No time to check under the bonnet this morning, due to the snow, so will go and have a look a bit later on for anything obvious, but can anyone give me any clues as to what's going on?
thanks!
