Author Topic: indicators not working  (Read 2213 times)
Offline ian007miles
« on: 17 December 2009, 12:07 »
hi can any one help i went out to my car the other day to charge the battery wen i but the battery back on i tryed all the electrics to make sure every thing was workin but as usual somthing went wrong :cry: i put the indicaters on the right side work put the left side dosnt front nor back so i put the hazard lights on and the same thing hapened and the little green light on the dash stays on it dosnt flash. but the funny thing is when i got out the car to go indoors i put the alarm on and all the indicators flashed so i went and checked the indicaters again and still nothing on the left side has any one had this problem before or no of what it is before i go pulling fuses relays and switches out thanx ian
« Last Edit: 17 December 2009, 16:44 by ian007miles »
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Re: indicators not working
« Reply #1 on: 22 December 2009, 00:29 »
Flasher relay I would suspect.
Offline ian007miles
« Reply #2 on: 22 December 2009, 08:26 »
but how come they still work wen the alarm is armed? :undecided:
« Reply #3 on: 22 December 2009, 08:34 »
probably because the alarm is wired direct to the indicator wires
Offline MK1 Ali!!
« Reply #4 on: 29 December 2009, 20:24 »
check the hazzard switch!! i know u only charged battery but the hazzard switch splits the circuit! try this!!,, pull the switch out of panel use a electricians flat blade to earth out the elements in switch and try the indicators. its worth a fidle anyway!!
